toto som vygooglil (je to na peugeot clube) co sa tyka mi-16 a cisiel ECU.
PEUGEOT 405 19L MI-16 (USA) 108KW 96027111 M13 CHK:77F0 BOSCH 0261200176 1267356021
PEUGEOT 405 19L MI-16 108KW 96027111 M13 CHK:6A5C BOSCH 0261200161 1267356020
PEUGEOT 405 19L MI-16 108KW 96027111 M13 CHK:77C1 BOSCH 0261200161 1267356020
PEUGEOT 405 19L MI-16 108KW 96027111 M13 CHK:77CA BOSCH 0261200161 1267356020
PEUGEOT 405 19L MI-16 116KW 96002910 ML41 CHK:2379 BOSCH 0261200119 1267355649
PEUGEOT 405 19L MI-16 116KW 96002910 ML41 CHK: DAEF BOSCH 0261200119 1267355335
PEUGEOT 405 19L MI-16 116KW 96002910 ML41 CHK:E3A5 BOSCH 0261200119 1267355335
PEUGEOT 405 19L MI-16 116KW 96027551 M13 CHK:42CA BOSCH B57995 0261200355 1267356758
PEUGEOT 405 19L MI-16 116KW 96027551 M13 CHK:4846 BOSCH 0261200355 1267356190
PEUGEOT 405 19L MI-16 116KW 96027551 M13 CHK:484E BOSCH 0261200355 1267356190
PEUGEOT 405 19L MI-16 116KW 96027551 M13 CHK:4852 BOSCH 0261200355 1267356190
PEUGEOT 405 19L MI-16 118KW 96131186 MP32 CHK:72CF BOSCH B57995 0261200218 1267357767
PEUGEOT 405 19L MI-16 118KW 96131186 MP32 CHK:73A3 BOSCH B57995 0261200218 1267358295
PEUGEOT 405 19L MI-16 118KW 96131186 MP32 CHK:7A36 BOSCH B57995 0261200218 2227355803
PEUGEOT 405 19L MI-16 118KW 96131186 MP32 CHK:7C02 BOSCH B57995 0261200218 1267357390
PEUGEOT 405 19L MI-16 118KW 96131186 MP32 CHK:82F1 BOSCH B57995 0261200218 1267355758
PEUGEOT 405 19L MI-16 16V 116KW 96026064 ML41 CHK:2B0C BOSCH 0261200125 1267355650
PEUGEOT 405 19L MI-16 16V 116KW 96026064 ML41 CHK:331C BOSCH 0261200140 1267356298
PEUGEOT 405 19L MI-16 4X4 116KW 192935 ML41 CHK:2021 BOSCH 0261200139 1267356117
PEUGEOT 405 19L MI-16 82KW 96010020 M13 CHK:3C9D BOSCH B57604 0261200159 1267355699
PEUGEOT 405 19L MI-16 82KW 96010020 M13 CHK:931A BOSCH B57604 0261200159 1267355657
PEUGEOT 405 19L MI-16 82KW 96074207 M13 CHK:6506 BOSCH B57605 0261200388 1267356133
PEUGEOT 405 19L MI-16 88KW 96012928 M13 CHK:94FA BOSCH 0261200162 1267355643
PEUGEOT 405 19L MI-16 88KW 96027112 M13 CHK:94F6 BOSCH 0261200160 1267355642
Kody motorů
- weslo
- Skutečné jméno: Peter
Re: Kody motorů
Peugeot 205 1.9 GTi 88kW
Peugeot 406 coupe 2.2HDi
ex - Peugeot 205 "STDT"
ex - Peugeot 106 S16
ex - Peugeot 205 GRD
ex - MB Vito
ex - MB Vito
- skardik
- Skutečné jméno: Jirka
Re: Kody motorů
Nevíte někdo jestli by motor 116kW jezdil s jednotkou na 108?
Mám totiž motor, na kterým není štítek, ale vyndaval se z auta bez katu, takže by měl být 116kW a k němu mám jednotku z jinýho auta 0261200161 na kterou jsem ten motor viděl nastartovanej. Je to blbost a motor je 108kW, nebo to jde?
A ještě nevíte někdo jak poznat typ motoru, když na něm není štítek?
Díky
Díky
IVECO Eurocargo E100
Octavia II 2.0FSi 4x4 LaK
Ford Transit Sněhurva
- TomGTI
Re: Kody motorů
Ano neměla KAT,Knock senzor a to třetí je lambda :lol:.Hasis píše:no ta silnejsi verze nemela kat, cidlo klepani a jeste neco myslim
Skardik:Velice jednoduše poznáš jestli máš verzi 108Kw nebo 116Kw a nepotřebuješ k tomu štítek,podívej se na vačkové kola,jsou na nich čísla,vždy jedno číslo na každém kole,tak na to mrkni a pak sem napiš jaké jsi tam našel čísla a já ti napíšu jaký máš motor.Jinak fungovat by to mělo 116Kw verze na jednotce 108Kw.
- skardik
Re: Kody motorů
Oki. Ráno kouknu. Díky za rady. Ještě mi prosím poraďte, kde najdu čidlo klepání. Díky
- Hasis
Re: Kody motorů
zepredu, dole uprostred na bloku
a je tam jen tak prisroubovane, samo od nej vede kabel
- skardik
Re: Kody motorů
Tak vám klucí děkuju. Mám samozřejmě DFW 108kW. Čidlo klepání tam je a vstřiky jsou BOSH O280150762. Na kladky jsem se nedostal, páč jsem musel do tý pitomý práce.
