Hmotnosti motorů PSA
kdyby to někoho zajímalo, tak jsem oběvil tohle
TU9M (954cc 8v alloy block monopoint injection) = 89kg
TU1M (1124cc 8v alloy block monopoint injection) = 90kg
TU3M (1360cc 8v alloy block monopoint injection) = 92kg
TU3FJ2 (1360cc 8v iron block injection) = 113kg
TU5JP (1587cc 8v iron block injection) = 109kg
TU5J4 (1587cc 16v iron block injection) = 117kg
TUD5 (1527cc 8v diesel) = 126kg
XU52C (1580cc 8v alloy block carb) = 107kg
XU5JP (1580cc 8v alloy block injection) = 108.5kg
XU7JP (1761cc 8v alloy block injection) = 114kg
XU7JP4 (1761cc 16v alloy block injection) = 125kg
XU92C (1905cc 8v alloy block carb) = 115kg
XU102C (1998cc 8v iron block carb) = 132kg
XU10J2C (1998cc 8v iron block injection) = 140kg
XU10J2TE (1998cc 8v iron block turbo) = 149kg
XU10J4 (1998v 16v iron block injection aka "S16") = 160kg
XU10J4TE (1998cc 16v iron block turbo aka "405 T16") = 165kg
XU10J4R (1998cc 16v iron block injection) = 143kg
XU10J4RS (1998cc 16v iron block injection aka "GTi-6") = 143kg
XUD7TE (1769xx 8v diesel) = 150kg
XUD9TE (1905cc 8v diesel) = 140kg
XUD11ATE (2088cc 12v diesel) = 171kg
DW10TD (1997cc 8v diesel) = 150kg
DW12TED4 (2179cc 16v diesel) = 182kg
EW7J4 (1749cc 16v alloy block injection) = 137.5kg
EW10J4 (1997cc 16v alloy block aka "206 GTi") - 137kg
EW12J4 (2230cc 16v alloy block injection) = 153kg
ES9J4 (2946cc 24v V6 alloy block) = 215kg
ES9J4S (2946cc 24v V6 alloy block) = 215kg
a tady převodovky včetně krouťáků co snesou
MA (rated to 138Nm) = 31.7kg
BE (rated between 210 and 250Nm) = 36.6kg
ML (rated between 300 and 350Nm) = 45 - 49.3kg
AL4 (rated to 200Nm) = 70kg
4HP20 (rated to 330Nm) = 88kg
Re: Hmotnosti motorů PSA
Super Nevis nahodou, jestli jsou to kompletne nastrojene motory, cim osazene? A jestli je to s naplnemi nebo bez?
- KuBik205
- Skutečné jméno: Jakub
- tel.:: 731221581
sakra jak to ze ten rozdil ?? XU10J4 (1998v 16v iron block injection aka "S16") = 160kg
si to přečtěte v originále
http://forum.205gtidrivers.com/index.ph ... 614&st=160
mělo by to být bez náplní ale asi i se sáním a svody.....
jinak u s16ky je jiný design hlavy než u gti6 (ty máš jedno ventilový víko, tam jsou dvě....)
pak to tvoje mohutný sání něco taky přidá.....
a míčko je na tom takhle
Engine weight (dry, no flywheel)
112.6kg
Engine weight (dry, with flywheel)
121.6kg
Engine weight (dry, with flywheel, alternator & starter)
132.7kg
112.6kg
121.6kg
132.7kg
- Michael205
- Skutečné jméno: Michal
- tel.:: 737350152
a u dieselu kam se ztratilo těch 10 kg ?
černý dábel 1.9 D - prodáno
Modré Cabrio 1.9 TD
Šedivý lev 306 HDi
Modré Cabrio 1.9 TD
Šedivý lev 306 HDi
no prý je to tim jak je vetší vrtání tak ubyl materiál z bloku...
- Michael205
- tel.:: 737350152
no dobře ale stejně to je dost když by to bylo jen vrtáním
Modré Cabrio 1.9 TD
Šedivý lev 306 HDi
Modré Cabrio 1.9 TD
Šedivý lev 306 HDi
ten litinovej blok holt váží pár kilo
hlavně 1.8D a 1.9D maj jiný sání a svody, takže tam taky může bejt pár kilo rozdíl
- Kenny
- tel.:: 773557950
sem si říkal že je to nějaký těžký
S timhle pod kapotou budou tvoje pružiny asi kratší než počítal výrobce pro gti :)
- KuBik205
- tel.:: 731221581
ta hlava mozna hodi nejakej rozdil ale to moje sani vazi 2,75 kg je z plastu totiz
to sice jo, ale tenmezikus se 4 klapkama asi bude něco vážit
- Milo75
- tel.:: 728845763
pěkné moje VMko v alfě váží 270Kg
Alfa Romeo 164 2,0V6
ex.205 1,8D utopeno
ex.205GTI diesel- prodáno
ex.205 1,8D utopeno
